Ga door naar hoofdinhoud
Olympus VR-350 LCD Screen Replacement
Wat je nodig hebt
  1. Olympus VR-350 LCD Screen Replacement, Front Plate: stap 1, afbeelding 1 van 2 Olympus VR-350 LCD Screen Replacement, Front Plate: stap 1, afbeelding 2 van 2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Olympus VR-350 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Olympus VR-350 LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 LCD Screen Replacement, Back Plate: stap 4, afbeelding 1 van 2 Olympus VR-350 LCD Screen Replacement, Back Plate: stap 4, afbeelding 2 van 2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 LCD Screen Replacement, LCD Screen: stap 5, afbeelding 1 van 2 Olympus VR-350 LCD Screen Replacement, LCD Screen: stap 5, afbeelding 2 van 2
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
  6. Olympus VR-350 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
  7. Olympus VR-350 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
Conclusie
Chloe
112 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-3, Leahy Winter 2015 Lid van USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,097
