Inleiding
Have you tried all the other manuals and still can't figure out what is wrong with your camera? Try replacing the motherboard by following these steps.
Wat je nodig hebt
Orient the camera so you are looking at the bottom.
Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
Remove the four 3mm Phillips #000 screws.
Use tweezers to remove metal plate
There is now full access to the motherboard which you can replace components on by soldering.
