Inleiding
Use this guide to remove the components of the Olympus Stylus Tough-8010 camera's lens component.
Wat je nodig hebt
Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
Take off smaller front cover.
Carefully remove larger front cover.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove four screws (9.4mm) on the front of the camera using a Phillips #000
Use the plastic opening tool to release the holding clip.
Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
Remove any tape on the flash component on the left.
Using tweezers, disconnect the plastic strip from its connector on the motherboard by lifting the plastic black flap on the connector and pulling the ribbon.
Using a #000 Philips head screwdriver remove four screws (4.1mm) on the metal plate.
Gently lift the flash components out of the camera casing.
