Ga door naar hoofdinhoud
Olympus Stylus Tough-6000 On/Off Button Replacement
Wat je nodig hebt
  1. Olympus Stylus Tough-6000 On/Off Button Replacement, Locate On/Off Button.: stap 1, afbeelding 1 van 1
    • First sit the camera on its bottom. You will be working on the on/off button.
  2. Olympus Stylus Tough-6000 On/Off Button Replacement: stap 2, afbeelding 1 van 1
    • Place camera upward.
    • You will notice two screws near the on/off button.
    • Use your Phillips #00 screwdriver to unscrew the two screws.
  3. Olympus Stylus Tough-6000 On/Off Button Replacement: stap 3, afbeelding 1 van 1
    • After unscrewing the two screws near the on/off button you will notice a single screw to your right.
    • Unscrew the single screw with your Phillips #00 screwdriver.
    • This will allow you to pry the panel off.
  4. Olympus Stylus Tough-6000 On/Off Button Replacement: stap 4, afbeelding 1 van 1
    • Grab your plastic opening tool and start prying off the panel.
  5. Olympus Stylus Tough-6000 On/Off Button Replacement: stap 5, afbeelding 1 van 1
    • Once the panel is lifted you will want to lift up the cover for the on/off button.
    • The actual on/off button is very small and loose so make sure to be careful with it!
  6. Olympus Stylus Tough-6000 On/Off Button Replacement: stap 6, afbeelding 1 van 1
    • You have reached the on/off button.
    • You can now replace it!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shannon Cooney
355 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 662
