Ga door naar hoofdinhoud
Olympus Stylus Tough-6000 Lens Cover Replacement
Wat je nodig hebt
  1. Olympus Stylus Tough-6000 Lens Cover Replacement, Disassemble Camera.: stap 1, afbeelding 1 van 1
    • You will want to disassemble the camera to get to the Lens Cover.
  2. Olympus Stylus Tough-6000 Lens Cover Replacement: stap 2, afbeelding 1 van 1
    • There are two screws on the right side of the camera.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Olympus Stylus Tough-6000 Lens Cover Replacement: stap 3, afbeelding 1 van 1
    • On the left side of the camera there will be another set of screws.
    • Unscrew both screws with the same Phillips #00 screwdriver.
  4. Olympus Stylus Tough-6000 Lens Cover Replacement: stap 4, afbeelding 1 van 1
    • After unscrewing the screws on the left side of the camera you will notice a speaker hat.
    • You will be able to pull the speaker hat off.
    • You must pull the speaker hat off to be able to pry the front shell of the camera apart.
  5. Olympus Stylus Tough-6000 Lens Cover Replacement: stap 5, afbeelding 1 van 1
    • Grab your plastic opening tool and begin to pry off the front shell of the camera.
    • The front shell will easily come off after a couple of prys.
  6. Olympus Stylus Tough-6000 Lens Cover Replacement: stap 6, afbeelding 1 van 1
    • Once you have the camera shell cover off you can see the lens cover.
    • Unscrew the lens cover with your Phillips #00 screwdriver to replace it with a new lens cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shannon Cooney
355 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,227
