Inleiding
Shutter button won’t respond when pressed? It may be time to replace or clean it. This guide will walk you through the simple steps to access and replace your shutter button.
Wat je nodig hebt
Locate the side of the camera with the connector cover.
Remove the 2 Phillips #00 4.6mm casing screws.
Locate the strap eyelet side of the camera and remove the 2 Phillips #00 5.3mm screws in the handle.
Using your fingers, take off the handle, the black casing underneath, and gently wiggle out the shiny black casing below that.
Remove the red ring surrounding the lens by twisting it counter-clockwise
To detach the monitor screen, remove the following 7 screws:
Locate the flash and remove the 2 Phillips #00 9.23mm & 14.87mm screws.
Locate the battery door and remove the single Phillips #00 3.37mm screw.
On the bottom of the camera, remove the single Phillips 3.58mm screw near the tripod socket.
On the face plate, locate and remove the 2 eyelet strap side Phillips #00 9.2mm corner screws and the lower battery corner Phillips #00 14.87mm screw.
Use your fingers to unclasp the casing clips on either side of the camera and pull down the monitor casing.
Using the spudger to gently pry the screen away from the body of the camera.
Remove the 2 Phillips (size) screws from the plastic housing surrounding the shutter button
Using your fingers gently remove the plastic piece covering the shutter and power button.
Place the camera lens side down.
Locate the center of the lens housing and disconnect the 2 largest ribbon cables by lifting the small flaps with your finger.
Remove the Phillips #00 screw and the silver metal tensioner below the screw. Remove the Phillips screw (size) next to the ribbon cable.
Rotate the camera to see the inside bottom of the shutter housing. You will see 2 ribbon cables.
At the base of the long ribbon, remove the blue tape and use the spudger to flip its clasp lifting it out.
At the base of the short ribbon, use the spudger to flip its clasp lifting it out.
Using your fingers or spudger, you may now remove the shutter board.
Één andere persoon heeft deze handleiding voltooid.
