Ga door naar hoofdinhoud
Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement
Wat je nodig hebt
  1. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: stap 1, afbeelding 1 van 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: stap 1, afbeelding 2 van 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: stap 1, afbeelding 3 van 3
    • Locate the battery/card cover on the bottom of the camera. .
    • Slide the tab labeled lock to show orange.
    • Slide the battery/card cover lock to revile orange and the door will spring open.
  2. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 2, afbeelding 1 van 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 2, afbeelding 2 van 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 2, afbeelding 3 van 3
    • Remove the 2 Phillips #00 screws on the inner battery door.
    • Use a spudger to release the seal and metal clip.
    • Replace the seal.
  3. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 3, afbeelding 1 van 2 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 3, afbeelding 2 van 2
    • Locate the connector cover on the side of the camera.
    • Slide the connector cover lock to revile orange and the door will spring open.
  4. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 4, afbeelding 1 van 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 4, afbeelding 2 van 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: stap 4, afbeelding 3 van 3
    • Remove the 2 Phillips #00 screws on the inner connector door.
    • Use a spudger to release the seal, the clear plastic piece, and the metal piece.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Amanda
933 Reputatie
8 handleidingen geschreven
3 opmerkingen
Where can I get the seals?
Ahmed - Antwoord
I have the same question. Where can I buy the seals? Olymus service man told me it is not possible to buy, and that I have to send TG-2 to service and pay about 100$.
adan - Antwoord
OK. Great instructions. I think I could do this, but where do I get the seals?
Steve Tobin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 2,066
