Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the 2 screws from the bottom of the camera
    • Remove the 2 screws from the bottom of the camera
  2. Remove the screw from the right side of the camera.
    • Remove the screw from the right side of the camera.
  3. Remove the two screws from the left side of the camera
    • Remove the two screws from the left side of the camera
  4. Separate the front casing from the back using a plastic opening tool, gently. Silver band and buttons will become loose when you remove the two pieces. Silver band and buttons will become loose when you remove the two pieces.
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  5. Pull the silver bracket and buttons off of the camera Pull the silver bracket and buttons off of the camera
    • Pull the silver bracket and buttons off of the camera
  6. Remove the 2 screws on the right side of the camera. Remove the 2 screws on the left side of the camera. Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
    • Remove the 2 screws on the right side of the camera.
    • Remove the 2 screws on the left side of the camera.
    • Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  7. Flip up clip on circuit ribbon, carefully
    • Flip up clip on circuit ribbon, carefully
    • Detach the ribbon from the rear to the front and pull it out, gently.
  8. You will be left with four major pieces
    • You will be left with four major pieces
Conclusie
Tracy Donovan
13 Reputatie
1 Handleiding geschreven
James Madison, Team 3-3, Klein Spring 2012 Lid van James Madison, Team 3-3, Klein Spring 2012
JMU-KLEIN-S12S3G3
4 Leden
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 6
Altijd: 401
