Ga door naar hoofdinhoud
Olympus Stylus 725 SW LCD Screen Replacement
Wat je nodig hebt
  1. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 1 van 2 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 2 van 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: stap 2, afbeelding 1 van 3 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: stap 2, afbeelding 2 van 3 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: stap 2, afbeelding 3 van 3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  3. Olympus Stylus 725 SW LCD Screen Replacement: stap 3, afbeelding 1 van 2 Olympus Stylus 725 SW LCD Screen Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  4. Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 3 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: stap 4, afbeelding 2 van 3 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: stap 4, afbeelding 3 van 3
    • Remove the screws in the back panel using a Phillips #00 screwdriver.
    • Detach the ribbon cables that connect the LCD to the back panel of the camera.
  5. Olympus Stylus 725 SW LCD Screen Replacement: stap 5, afbeelding 1 van 2 Olympus Stylus 725 SW LCD Screen Replacement: stap 5, afbeelding 2 van 2
    Koop
    • Use tweezers to remove the loosened LCD screen.
    • Be careful to not scratch the new LCD screen when replacing it.
    • Carefully place the new screen in place of the old, making sure the label faces up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bobby Hodges
49 Reputatie
6 handleidingen geschreven
Cal Poly, Team 33-71, Johann Spring 2010 Lid van Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 8,018
