Ga door naar hoofdinhoud
Olympus Stylus 410 Speaker Replacement
Wat je nodig hebt
  1. Olympus Stylus 410 Speaker Replacement, Outer Case: stap 1, afbeelding 1 van 3 Olympus Stylus 410 Speaker Replacement, Outer Case: stap 1, afbeelding 2 van 3 Olympus Stylus 410 Speaker Replacement, Outer Case: stap 1, afbeelding 3 van 3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Speaker Replacement: stap 2, afbeelding 1 van 2 Olympus Stylus 410 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  3. Olympus Stylus 410 Speaker Replacement: stap 3, afbeelding 1 van 2 Olympus Stylus 410 Speaker Replacement: stap 3, afbeelding 2 van 2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  4. Olympus Stylus 410 Speaker Replacement: stap 4, afbeelding 1 van 2 Olympus Stylus 410 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  5. Olympus Stylus 410 Speaker Replacement: stap 5, afbeelding 1 van 3 Olympus Stylus 410 Speaker Replacement: stap 5, afbeelding 2 van 3 Olympus Stylus 410 Speaker Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  6. Olympus Stylus 410 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  7. Olympus Stylus 410 Speaker Replacement: stap 7, afbeelding 1 van 2 Olympus Stylus 410 Speaker Replacement: stap 7, afbeelding 2 van 2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  8. Olympus Stylus 410 Speaker Replacement, Speaker: stap 8, afbeelding 1 van 3 Olympus Stylus 410 Speaker Replacement, Speaker: stap 8, afbeelding 2 van 3 Olympus Stylus 410 Speaker Replacement, Speaker: stap 8, afbeelding 3 van 3
    • Use a spudger to remove the speaker. It is attached by a double sided adhesive so it should just peel off.
  9. Olympus Stylus 410 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Un-solder the wires to remove the speaker.
Conclusie
Gabriela Igel
27 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-13, Maness Spring 2010 Lid van Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,392
