Ga door naar hoofdinhoud
Olympus Stylus 410 Battery Cover Replacement
Wat je nodig hebt
  1. Olympus Stylus 410 Battery Cover Replacement, Slider: stap 1, afbeelding 1 van 1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Battery Cover Replacement: stap 2, afbeelding 1 van 1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Battery Cover Replacement: stap 3, afbeelding 1 van 1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Battery Cover Replacement: stap 4, afbeelding 1 van 1
    • The slider should now be free from the body of the camera.
  5. Olympus Stylus 410 Battery Cover Replacement, Outer Case: stap 5, afbeelding 1 van 3 Olympus Stylus 410 Battery Cover Replacement, Outer Case: stap 5, afbeelding 2 van 3 Olympus Stylus 410 Battery Cover Replacement, Outer Case: stap 5, afbeelding 3 van 3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Olympus Stylus 410 Battery Cover Replacement: stap 6, afbeelding 1 van 2 Olympus Stylus 410 Battery Cover Replacement: stap 6, afbeelding 2 van 2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Olympus Stylus 410 Battery Cover Replacement: stap 7, afbeelding 1 van 2 Olympus Stylus 410 Battery Cover Replacement: stap 7, afbeelding 2 van 2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Olympus Stylus 410 Battery Cover Replacement: stap 8, afbeelding 1 van 2 Olympus Stylus 410 Battery Cover Replacement: stap 8, afbeelding 2 van 2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Olympus Stylus 410 Battery Cover Replacement: stap 9, afbeelding 1 van 3 Olympus Stylus 410 Battery Cover Replacement: stap 9, afbeelding 2 van 3 Olympus Stylus 410 Battery Cover Replacement: stap 9, afbeelding 3 van 3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Olympus Stylus 410 Battery Cover Replacement: stap 10, afbeelding 1 van 1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Olympus Stylus 410 Battery Cover Replacement: stap 11, afbeelding 1 van 2 Olympus Stylus 410 Battery Cover Replacement: stap 11, afbeelding 2 van 2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  12. Olympus Stylus 410 Battery Cover Replacement, Battery Cover: stap 12, afbeelding 1 van 2 Olympus Stylus 410 Battery Cover Replacement, Battery Cover: stap 12, afbeelding 2 van 2
    • Open the battery cover and lift it up and off of back camera case.
  13. Olympus Stylus 410 Battery Cover Replacement: stap 13, afbeelding 1 van 3 Olympus Stylus 410 Battery Cover Replacement: stap 13, afbeelding 2 van 3 Olympus Stylus 410 Battery Cover Replacement: stap 13, afbeelding 3 van 3
    • Locate and unscrew the 2 screws with a #00 Phillips screwdriver.
    • Remove the black seal.
  14. Olympus Stylus 410 Battery Cover Replacement: stap 14, afbeelding 1 van 2 Olympus Stylus 410 Battery Cover Replacement: stap 14, afbeelding 2 van 2
    • Slide the metal piece off of the battery cover.
  15. Olympus Stylus 410 Battery Cover Replacement: stap 15, afbeelding 1 van 1
    • This is what the battery cover and back case look like completely disassembled.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rory Aronson
46 Reputatie
6 handleidingen geschreven
Cal Poly, Team 6-13, Maness Spring 2010 Lid van Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Leden
17 handleidingen geschreven
Één opmerking
i need Battery where i can find it thinks
uae20162017 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 2,898
