Inleiding
The device being repaired is the Olympus Stylus 1030 SW. The goal of this guide is to remove and replace the flash assembly. Before starting to disassemble your camera make sure it is powered off and the battery is removed.
Wat je nodig hebt
Remove the three screws in the corner of the front plate using a Phillips #00 screwdriver.
Lift up on the plate until it comes off the rest of the camera.
Face the camera so the short side with the AV port facing you. Use your Phillips #00 screwdriver to remove the single screw.
Turn your camera so the other short side is facing you. Use the Phillips #00 screwdriver to remove the two screws on the silver parts.
Face the bottom of your camera towards you and remove the single screw using the Phillips #00 screwdriver.
