Ga door naar hoofdinhoud
Olympus Stylus 1010 Motherboard Replacement
Wat je nodig hebt
  1. Olympus Stylus 1010 Motherboard Replacement, Disassembling Olympus Stylus 1010 Case: stap 1, afbeelding 1 van 2 Olympus Stylus 1010 Motherboard Replacement, Disassembling Olympus Stylus 1010 Case: stap 1, afbeelding 2 van 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 Motherboard Replacement: stap 3, afbeelding 1 van 2 Olympus Stylus 1010 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 Motherboard Replacement: stap 6, afbeelding 1 van 3 Olympus Stylus 1010 Motherboard Replacement: stap 6, afbeelding 2 van 3 Olympus Stylus 1010 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 Motherboard Replacement: stap 7, afbeelding 1 van 3 Olympus Stylus 1010 Motherboard Replacement: stap 7, afbeelding 2 van 3 Olympus Stylus 1010 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 Motherboard Replacement, Lens: stap 8, afbeelding 1 van 2 Olympus Stylus 1010 Motherboard Replacement, Lens: stap 8, afbeelding 2 van 2
    • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
  9. Olympus Stylus 1010 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the three screws from the inside of the camera using a #00 screwdriver.
  10. Olympus Stylus 1010 Motherboard Replacement: stap 10, afbeelding 1 van 2 Olympus Stylus 1010 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
  11. Olympus Stylus 1010 Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 1
    • Remove the two Phillips #00 screws on the right side of the camera.
  12. Olympus Stylus 1010 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Still using the spudger, detach the gold wire tape connectors from the motherboard.
  13. Olympus Stylus 1010 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Desolder the upper right and lower left wires to remove the motherboard.
  14. Olympus Stylus 1010 Motherboard Replacement: stap 14, afbeelding 1 van 2 Olympus Stylus 1010 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • In order to remove the motherboard, grab each side of it and pull up using your thumb and forefinger.
Conclusie
Max McIntyre
526 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-4, Forte Winter 2011 Lid van Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 3,199
