Ga door naar hoofdinhoud
Olympus Stylus 1010 LCD Display Replacement
Wat je nodig hebt
  1. Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: stap 1, afbeelding 1 van 2 Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: stap 1, afbeelding 2 van 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 LCD Display Replacement: stap 2, afbeelding 1 van 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 LCD Display Replacement: stap 3, afbeelding 1 van 2 Olympus Stylus 1010 LCD Display Replacement: stap 3, afbeelding 2 van 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 LCD Display Replacement: stap 4, afbeelding 1 van 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 LCD Display Replacement: stap 5, afbeelding 1 van 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 LCD Display Replacement: stap 6, afbeelding 1 van 3 Olympus Stylus 1010 LCD Display Replacement: stap 6, afbeelding 2 van 3 Olympus Stylus 1010 LCD Display Replacement: stap 6, afbeelding 3 van 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 LCD Display Replacement: stap 7, afbeelding 1 van 3 Olympus Stylus 1010 LCD Display Replacement: stap 7, afbeelding 2 van 3 Olympus Stylus 1010 LCD Display Replacement: stap 7, afbeelding 3 van 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 LCD Display Replacement, LCD Display: stap 8, afbeelding 1 van 1
    • Peel up the blue and black tape. This can be done with a spudger.
  9. Olympus Stylus 1010 LCD Display Replacement: stap 9, afbeelding 1 van 2 Olympus Stylus 1010 LCD Display Replacement: stap 9, afbeelding 2 van 2
    • Unscrew the screws. (6 screws)( photo shows 7 screws -editorial comment)
  10. Olympus Stylus 1010 LCD Display Replacement: stap 10, afbeelding 1 van 2 Olympus Stylus 1010 LCD Display Replacement: stap 10, afbeelding 2 van 2
    • Push out the LCD screen by pushing on the screen side.
Conclusie
Curtis Reedy
267 Reputatie
2 handleidingen geschreven
Cal Poly, Team 13-4, Forte Winter 2011 Lid van Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 4,547
