Ga door naar hoofdinhoud
Olympus SZ-12 LCD Screen Replacement
Wat je nodig hebt
  1. Olympus SZ-12 LCD Screen Replacement, Back Case: stap 1, afbeelding 1 van 2 Olympus SZ-12 LCD Screen Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 LCD Screen Replacement, LCD Screen: stap 7, afbeelding 1 van 1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
Conclusie
Samuel Hays
515 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 555
