Ga door naar hoofdinhoud
Olympus SP-320 Motherboard Replacement
Wat je nodig hebt
  1. Olympus SP-320 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Olympus SP-320 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Olympus SP-320 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Motherboard Replacement: stap 3, afbeelding 1 van 2 Olympus SP-320 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Motherboard Replacement: stap 4, afbeelding 1 van 3 Olympus SP-320 Motherboard Replacement: stap 4, afbeelding 2 van 3 Olympus SP-320 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Motherboard Replacement: stap 5, afbeelding 1 van 2 Olympus SP-320 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
  6. Olympus SP-320 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove motherboard.
Conclusie
2 opmerkingen
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - Antwoord
It would be nice to know why you needed to access the motherboard.
John - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 542
