Ga door naar hoofdinhoud
Olympus SP-320 Back casing and LCD screen Replacement
Wat je nodig hebt
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: stap 1, afbeelding 1 van 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: stap 1, afbeelding 2 van 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: stap 1, afbeelding 3 van 3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: stap 3, afbeelding 1 van 1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: stap 4, afbeelding 1 van 3 Olympus SP-320 Back casing and LCD screen Replacement: stap 4, afbeelding 2 van 3 Olympus SP-320 Back casing and LCD screen Replacement: stap 4, afbeelding 3 van 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: stap 5, afbeelding 1 van 3 Olympus SP-320 Back casing and LCD screen Replacement: stap 5, afbeelding 2 van 3 Olympus SP-320 Back casing and LCD screen Replacement: stap 5, afbeelding 3 van 3
    • You have detached the back casing and LCD screen.
Conclusie
Één opmerking
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 538
