Ga door naar hoofdinhoud
Olympus Pen E-PL7 LCD Screen Replacement
Wat je nodig hebt
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Olympus Pen E-PL7 LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Olympus Pen E-PL7 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: stap 4, afbeelding 1 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 4, afbeelding 2 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 4, afbeelding 3 van 3
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: stap 6, afbeelding 1 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 6, afbeelding 2 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: stap 7, afbeelding 1 van 2 Olympus Pen E-PL7 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Use tweezers to peel back the plastic cover.
  8. Olympus Pen E-PL7 LCD Screen Replacement: stap 8, afbeelding 1 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 8, afbeelding 2 van 3 Olympus Pen E-PL7 LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Olympus Pen E-PL7 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove the LCD Screen.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Kelsea Weber
19.857 Reputatie
32 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.757 handleidingen geschreven
7 opmerkingen
Magnifico
Great Work!!
apuntotres - Antwoord
Where can I buy a replacement LCD screen?
Joshua Almeida - Antwoord
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - Antwoord
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - Antwoord
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 74
Altijd: 9,822
