Ga door naar hoofdinhoud
Olympus OM-D E-M10 Mark II Screen Replacement
Wat je nodig hebt
  1. Olympus OM-D E-M10 Mark II Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Olympus OM-D E-M10 Mark II Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II Screen Replacement: stap 2, afbeelding 1 van 1
    • Extend out the screen so you can reach the screws. Remove the a total of four screws using a Phillips #00 at the top and the back of the screen.
    • This step has two types of screws. (2x) 3.5 mm on the top, (2x) 1.7 mm on the back.
  3. Olympus OM-D E-M10 Mark II Screen Replacement: stap 3, afbeelding 1 van 1
    • Pull the screen away from the base of the camera. Then disconnect the cable connectors from the circuit board. Be sure to remove the smaller circuit board with care.
  4. Olympus OM-D E-M10 Mark II Screen Replacement: stap 4, afbeelding 1 van 1
    • Separate the screen from the camera. Now you are able to install your replacement screen
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Connor Langguth
346 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G5, Hovde Fall 2019 Lid van IUPUI, Team S1-G5, Hovde Fall 2019
IUPUI-HOVDE-F19S1G5
3 Leden
5 handleidingen geschreven
4 opmerkingen
Hi, do you know if the LCD screen from the Mark II is the exact same as the Mark III? I see replacements for the Mark II being sold, but they don’t say whether they’re compatible.
Solomon Krause-Imlach - Antwoord
Hey Solomon I am experiencing the same issue. Did you find out if they are exactly the same?? My LCD screen no longer functions and all I come across online is the Mark II LCD's.
Zacharia Gupta -
Hi, do you know where I can buy the screen?
Thanks
Lorenzo
Lorenzo Zaccarini - Antwoord
If you order only panel like me, theres few wery scary parts more. You have to remove couple pcb's, trying get connectors back in and you definetly need elastic glue for glueing screen back.
Mikko Hyvärinen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 62
Afgelopen 30 dagen: 229
Altijd: 10,317
