Ga door naar hoofdinhoud
Olympus OM-D E-M10 Mark II Lens Replacement
  1. Olympus OM-D E-M10 Mark II Lens Replacement, Lens: stap 1, afbeelding 1 van 1
    • Press the black button located to the right of the camera lens when facing the front of the camera.
  2. Olympus OM-D E-M10 Mark II Lens Replacement: stap 2, afbeelding 1 van 1
    • Grasp the innermost ring on the lens, closest to the camera body, which can be located by the small red dot. This is the only ring that should not turn, unless the button specified in the previous step is held down.
  3. Olympus OM-D E-M10 Mark II Lens Replacement: stap 3, afbeelding 1 van 1
    • While holding down the button specified in step 1, begin turning the inner most ring, specified in step 2, counterclockwise until the camera lens becomes free from the camera body.
  4. Olympus OM-D E-M10 Mark II Lens Replacement: stap 4, afbeelding 1 van 1
    • Once the lens is free from the camera body, pull the lens completely away from the body to make sure the lens is truly free.
Conclusie
Channing Pezet
214 Reputatie
2 handleidingen geschreven
USF Tampa, Team S5-G6, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S5G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 53
Altijd: 3,987
