Ga door naar hoofdinhoud
Olympus OM-D E-M10 Mark II Flash Replacement
Wat je nodig hebt
  1. Olympus OM-D E-M10 Mark II Flash Replacement, Motherboard: stap 1, afbeelding 1 van 2 Olympus OM-D E-M10 Mark II Flash Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II Flash Replacement: stap 2, afbeelding 1 van 2 Olympus OM-D E-M10 Mark II Flash Replacement: stap 2, afbeelding 2 van 2
    • Remove eight screws using a Phillips #00 screwdriver.
    • There are 3 different screws, (2x) 3 mm, (3x) 2.5 mm, (3x) 4 mm.
  3. Olympus OM-D E-M10 Mark II Flash Replacement: stap 3, afbeelding 1 van 1
    • Lift and remove the bottom cover off the camera.
  4. Olympus OM-D E-M10 Mark II Flash Replacement: stap 4, afbeelding 1 van 1
    • Using the Phillips #00 remove two 5.0 mm screws, one from each side of the base of the camera.
  5. Olympus OM-D E-M10 Mark II Flash Replacement: stap 5, afbeelding 1 van 1
    • Turn the camera over until it is laying on its backside. Open the screen until it fully extended and perpendicular as shown below. Remove the three screws located there with the Phillips #00.
    • There are two different types of screws. (2x) 2.7 mm, (1x) 3.5 mm.
  6. Olympus OM-D E-M10 Mark II Flash Replacement: stap 6, afbeelding 1 van 1
    • Turn the camera over on its side as shown. There is a small compartment door that has a screw located underneath it. Remove the 2.5 mm screw with a Phillips #00 screwdriver.
  7. Olympus OM-D E-M10 Mark II Flash Replacement: stap 7, afbeelding 1 van 2 Olympus OM-D E-M10 Mark II Flash Replacement: stap 7, afbeelding 2 van 2
    • Take the front and back of the camera apart.
    • Be careful when taking the front and back of the camera apart because there are connecters to the motherboard from both halves which are very fragile. In order to fully take the two halves apart you will need to unhook the connectors from the motherboard.
  8. Olympus OM-D E-M10 Mark II Flash Replacement: stap 8, afbeelding 1 van 1
    • Position the front half as depicted below. The motherboard is the green computer chip on the right half the picture below. You will need to disconnect everything from the motherboard. Gently pull out all orange connectors.
  9. Olympus OM-D E-M10 Mark II Flash Replacement: stap 9, afbeelding 1 van 1
    • Using a Phillips #00 remove the three 3.0 mm screws while holding the motherboard in place. You should then be able to gently remove the motherboard.
  10. Olympus OM-D E-M10 Mark II Flash Replacement, Flash: stap 10, afbeelding 1 van 1
    • See the Olympus OM -D E-M10 Mark II guide for motherboard replacement and follow the guide until the motherboard is exposed
  11. Olympus OM-D E-M10 Mark II Flash Replacement: stap 11, afbeelding 1 van 2 Olympus OM-D E-M10 Mark II Flash Replacement: stap 11, afbeelding 2 van 2
    • Remove the +/- cover in the center of the dial by levering the small indent.
    • Remove the screw found below the cover.
  12. Olympus OM-D E-M10 Mark II Flash Replacement: stap 12, afbeelding 1 van 3 Olympus OM-D E-M10 Mark II Flash Replacement: stap 12, afbeelding 2 van 3 Olympus OM-D E-M10 Mark II Flash Replacement: stap 12, afbeelding 3 van 3
    • Remove three screws from the front casing of the viewfinder
    • Remove the front casing of the viewfinder, being mindful of any ribbons which may be connected to other components
  13. Olympus OM-D E-M10 Mark II Flash Replacement: stap 13, afbeelding 1 van 2 Olympus OM-D E-M10 Mark II Flash Replacement: stap 13, afbeelding 2 van 2
    • Remove the two screws on the front of flash component.
    • Remove the outer gray casing of the flash component by using a spudger to separate the black and gray plastic pieces.
    • Use a soldering iron to replace the broken component of the flash connected to the circuit board.
Conclusie
Wyatt Highland
109 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Harley Spring 2022 Lid van IUPUI, Team 2-2, Harley Spring 2022
IUPUI-HARLEY-S22S2G2
4 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 624
