Ga door naar hoofdinhoud
Olympus Digital Camera TG-3 Shutter Button Replacement
Wat je nodig hebt
  1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Front Case: stap 1, afbeelding 1 van 1
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
    Vraag FixBot
  2. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 2, afbeelding 1 van 1
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
    Vraag FixBot
  3. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 3, afbeelding 1 van 1
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
    Vraag FixBot
  4. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 4, afbeelding 1 van 1
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
    Vraag FixBot
  5. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 5, afbeelding 1 van 1
    • Now you should be able to remove the front case easily using your hand.
    Vraag FixBot
  6. Olympus Digital Camera TG-3 Shutter Button  Replacement, Back Case: stap 6, afbeelding 1 van 1
    • Using the PH000 screwdriver, remove the two 4mm screws located on the left side of the camera, under the strap holder.
    Vraag FixBot
  7. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 7, afbeelding 1 van 1
    • Use a PH000 screwdriver to remove the 3 mm screw located on the bottom of the battery compartment.
    Vraag FixBot
  8. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 8, afbeelding 1 van 1
    • Hold the device as shown in the picture. Using the PH000 screwdriver, remove the 9mm screw located on the upper left side of the camera.
    Vraag FixBot
  9. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 9, afbeelding 1 van 1
    • Use the PH000 screwdriver to remove the 7mm screw you'll find toward the lower left side of the camera.
    Vraag FixBot
  10. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 10, afbeelding 1 van 1
    • Use a PH000 screwdriver to remove the 6mm screw on the upper right side of the camera, above the flash.
    Vraag FixBot
  11. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 11, afbeelding 1 van 1
    • Using the PH000 screwdriver, remove the 1.2 mm located on the lower right side of the device, towards the corner.
    Vraag FixBot
  12. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 12, afbeelding 1 van 1
    • Use the PH0000 screwdriver to remove the 7 mm located on the upper side of the camera, where the shutter and zoom bottoms are. You will find the screw towards the middle of this section.
    Vraag FixBot
  13. Olympus Digital Camera TG-3 Shutter Button  Replacement: stap 13, afbeelding 1 van 1
    • Remove the back case using your hand.
    Vraag FixBot
Conclusie
4 andere personen hebben deze handleiding voltooid.
Natalia Morales
675 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-6, Leahy Fall 2016 Lid van USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Leden
10 handleidingen geschreven
2Gids Commentaar
Bravo super tutorial, but how to ensure the sealing after disassembly and reassembly?
vincent vidal - Antwoord Deel
I have a problem recovering the original condition. Is it possible Someone help me to restore it. Olympus TG-3 contact back. Witrocker@hotmail.com
Dawis rocker - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 82
Altijd: 4,217
