Ga door naar hoofdinhoud
Olympus D590 Backplate Replacement
Wat je nodig hebt
  1. Olympus D590 Backplate Replacement, Face Plate: stap 1, afbeelding 1 van 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Backplate Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Backplate Replacement: stap 3, afbeelding 1 van 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Backplate Replacement: stap 4, afbeelding 1 van 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Backplate Replacement: stap 5, afbeelding 1 van 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Backplate Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Backplate Replacement: stap 7, afbeelding 1 van 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Backplate Replacement, Backplate: stap 8, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
  9. Olympus D590 Backplate Replacement: stap 9, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
  10. Olympus D590 Backplate Replacement: stap 10, afbeelding 1 van 1
    • Using an iFixit opening tool, pry the backplate from the camera internal housing component.
  11. Olympus D590 Backplate Replacement: stap 11, afbeelding 1 van 1
    • Pull the backplate away from the camera internal housing component.
Conclusie
Katie
31 Reputatie
3 handleidingen geschreven
Cal Poly, Team 28-23, Regan Spring 2010 Lid van Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,059
