Ga door naar hoofdinhoud
Olympus Camedia D560 Rear Panel Control Buttons Replacement
Wat je nodig hebt
  1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: stap 1, afbeelding 1 van 2 Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: stap 1, afbeelding 2 van 2
    • Before disassembling your camera, be sure it is powered off.
    • Remove two screws from the video port located at the side panel of the camera.
    • Remove three screws from the bottom panel of the camera.
  2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 2, afbeelding 1 van 2 Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 2, afbeelding 2 van 2
    • Open the USB port cover, and remove three screws from inside.
    • Next, open the memory slot cover and remove the screw.
  3. Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 3, afbeelding 1 van 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 3, afbeelding 2 van 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 3, afbeelding 3 van 3
    • Use the blue opening tool to loosen and separate the back cover from the camera.
  4. Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 4, afbeelding 1 van 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 4, afbeelding 2 van 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 4, afbeelding 3 van 3
    • Locate and unscrew the three screws inside the back cover body (picture 3) .
    • Remove button pad assembly from the back cover.
  5. Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 5, afbeelding 1 van 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 5, afbeelding 2 van 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: stap 5, afbeelding 3 van 3
    • The button assembly is now separate from the back cover.
    • Inspect for broken areas. Replace or clean the button parts.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
GradStudents2011
21 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 992
