Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
A bad board may be responsible for a overall dead camera operations. If the board is malfunctioning it must be replaced to fix the problem. This guide involves multiple steps including soldering and other difficult steps.
Wat je nodig hebt
Remove all of the screws that hold the back plate in place.
Unscrew the 4mm screw that is directly to the right of the viewfinder.
On the base,
Unscrew the 3mm screw in the top left corner.
Unscrew all four 3mm screws under the battery cover.
Unscrew the 3mm screw on the right side panel.
Unscrew the two 2mm screws on the left side panel.
Loosen the ribbon cables from the board.
1-Directly below the viewfinder.
2-At the Base of the board.
3-At the top right near the selector wheel. 1 on top of the board 2 on the underside.
1-The center of the board, above the central hole.
With metal tweezers, remove the two white plastic clips from their sockets one on the base of the board and the other on the surface.
