Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Olympus C-765 Mother Board Replacement
Wat je nodig hebt
  1. Olympus C-765 Mother Board Replacement, Mother Board: stap 1, afbeelding 1 van 3 Olympus C-765 Mother Board Replacement, Mother Board: stap 1, afbeelding 2 van 3 Olympus C-765 Mother Board Replacement, Mother Board: stap 1, afbeelding 3 van 3
    • Remove all of the screws that hold the back plate in place.
    • Unscrew the 4mm screw that is directly to the right of the viewfinder.
    • On the base,
    • Unscrew the 3mm screw in the top left corner.
    • Unscrew all four 3mm screws under the battery cover.
    • Unscrew the 3mm screw on the right side panel.
    • Unscrew the two 2mm screws on the left side panel.
    • The bullets apply to the three pictures on the step.
  2. Olympus C-765 Mother Board Replacement: stap 2, afbeelding 1 van 2 Olympus C-765 Mother Board Replacement: stap 2, afbeelding 2 van 2
    • Now remove the back panel completely.
    • Gently rock the 2 ribbon cables from their sockets.
    • With metal tweezers, grasp and pull white cable out of its clip.
  3. Olympus C-765 Mother Board Replacement: stap 3, afbeelding 1 van 1
    • On the surface of the board,
    • Peel off the plastic sheets on the board.
    • Unscrew 2-3mm from the board itself.
  4. Olympus C-765 Mother Board Replacement: stap 4, afbeelding 1 van 3 Olympus C-765 Mother Board Replacement: stap 4, afbeelding 2 van 3 Olympus C-765 Mother Board Replacement: stap 4, afbeelding 3 van 3
    • Loosen the ribbon cables from the board.
    • 1-Directly below the viewfinder.
    • 2-At the Base of the board.
    • 3-At the top right near the selector wheel. 1 on top of the board 2 on the underside.
    • 1-The center of the board, above the central hole.
    • With metal tweezers, remove the two white plastic clips from their sockets one on the base of the board and the other on the surface.
  5. Olympus C-765 Mother Board Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 3 mm ground screw attached to the camera body.
  6. Olympus C-765 Mother Board Replacement: stap 6, afbeelding 1 van 1
    • The motherboard has two solder connections that need to be desoldered to remove the board.
    • Don't attempt to unsolder the joints without previous knowledge of soldering
    • When soldering avoiding touching any other components with the iron
  7. Olympus C-765 Mother Board Replacement: stap 7, afbeelding 1 van 1
    • Once we have the mother board removed it can be replaced with a new board.
    • While the mother board is removed it is possible to get further into the camera itself to make more repairs.
Conclusie
Mason Morgan
115 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-33, Maness Spring 2011 Lid van Cal Poly, Team 12-33, Maness Spring 2011
CPSU-MANESS-S11S12G33
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 3,342
