Inleiding
The vent engine is the key mechanical assembly that controls airflow in the ventilator. This guide will show you how to replace the vent engine if your current ventilator has a faulty one.
For more information on removing the vent engine, please refer to page 9-5 (section 9.3.2) in the technical manual.
Wat je nodig hebt
With the main chassis separated from the cart, position the device upright with the monitor centered to prevent any tipping.
Disconnect any external connectors as well as the display connector.
