Ga door naar hoofdinhoud
Office Chair Gas Cylinder Replacement
Wat je nodig hebt
  1. Office Chair Gas Cylinder Replacement, Gas Cylinder: stap 1, afbeelding 1 van 1
    • Place the chair horizontally, putting it on its side.
  2. Office Chair Gas Cylinder Replacement: stap 2, afbeelding 1 van 1
    • The base is connected to the chair either with retaining clips or nuts and bolts at its center.
    • Remove the retaining clips or unscrew the nuts and bolts with a wrench or drill.
    • Remove the base of the chair.
  3. Office Chair Gas Cylinder Replacement: stap 3, afbeelding 1 van 1
    • Place a pipe wrench on the gas cylinder, and spray it with WD-40 to lubricate it and make it easier to remove.
    • Twist and pull the wrench to loosen the cylinder and remove it from its place.
  4. Office Chair Gas Cylinder Replacement: stap 4, afbeelding 1 van 1
    • Look up the chair's part number to find which gas cylinders are compatible with your chair.
  5. Office Chair Gas Cylinder Replacement: stap 5, afbeelding 1 van 1
    • Be sure to follow the instructions for your specific gas cylinder, since installation procedures may vary.
    • Place the tapered part of the cylinder into the column and rotate it into place.
    • Reconnect the base of the chair.
    • Place the chair upright and adjust the chair to your preferred height. Test it out by sitting on it.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Christian Phillip
170 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 136
Altijd: 10,486
