Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The following steps will guide you through the process of taking apart the Oculus Rift headset to replace the Tracker V2 Board. The Tracker V2 board is the Oculus Rifts Accelerometer and allows it to track your movement. You may need to replace the tracker if the headset does not register your movements, even after it has been calibrated.
Wat je nodig hebt
To remove the lenses, turn the right lens clockwise a quarter turn and the left lens counter-clockwise a quarter turn.
Use a Phillips #01 screwdriver to unscrew the four 9 mm Phillips #01 screws. (Two screws are shown in the picture, and two more screws are on the left side across from the right screws.)
Remove wires from the Tracker V2 Board using your fingernail or a plastic opening tool.
Één andere persoon heeft deze handleiding voltooid.
