Ga door naar hoofdinhoud
Oculus Rift DK1 Display Replacement
Wat je nodig hebt
  1. Oculus Rift DK1 Display Replacement, Lens: stap 1, afbeelding 1 van 2 Oculus Rift DK1 Display Replacement, Lens: stap 1, afbeelding 2 van 2
    • To remove the lenses, turn the right lens clockwise a quarter turn and the left lens counter-clockwise a quarter turn.
  2. Oculus Rift DK1 Display Replacement, Display: stap 2, afbeelding 1 van 2 Oculus Rift DK1 Display Replacement, Display: stap 2, afbeelding 2 van 2
    • Use a Phillips #01 screwdriver to unscrew the four 9 mm Phillips #01 screws. (Two screws are shown in the picture, and two more screws are on the left side across from the right screws.)
  3. Oculus Rift DK1 Display Replacement: stap 3, afbeelding 1 van 3 Oculus Rift DK1 Display Replacement: stap 3, afbeelding 2 van 3 Oculus Rift DK1 Display Replacement: stap 3, afbeelding 3 van 3
    • Carefully lift the headstrap from the display. The two parts should separate easily enough with some force.
    • Once the headstrap assembly and display box are separated, the headstrap assembly can be set aside. You will be working with the display box for the rest of this guide!
  4. Oculus Rift DK1 Display Replacement: stap 4, afbeelding 1 van 2 Oculus Rift DK1 Display Replacement: stap 4, afbeelding 2 van 2
    • Using the plastic opening tool, pry open the display box to reveal the LCD (Liquid Crystal Display) screen. Run the plastic opening tool around all four edges. Prying open the box may take a good amount of force.
  5. Oculus Rift DK1 Display Replacement: stap 5, afbeelding 1 van 3 Oculus Rift DK1 Display Replacement: stap 5, afbeelding 2 van 3 Oculus Rift DK1 Display Replacement: stap 5, afbeelding 3 van 3
    • Run the plastic opening tool along the bottom edge under the LCD screen to separate the adhesive holding the LCD to the display box.
    • Lift the screen up to reveal the wires and circuit board.
    • Ensure that all wires are in the right place upon reassembly.
  6. Oculus Rift DK1 Display Replacement: stap 6, afbeelding 1 van 2 Oculus Rift DK1 Display Replacement: stap 6, afbeelding 2 van 2
    • Remove the wires from the circuit board on the LCD display using your fingernail or a plastic opening tool. This may take some pushing and pulling of the plastic piece.
    • Don't pull on the wires! Be sure to only pry the plastic part.
    • You can now completely separate the LCD screen from the rest of the device!
Conclusie
5 andere personen hebben deze handleiding voltooid.
Paula Ledgerwood
271 Reputatie
1 Handleiding geschreven
Cal Poly, Team 70-5, Forte Winter 2015 Lid van Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Leden
6 handleidingen geschreven
Één opmerking
testtesttesttest
d
cybname - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 3,648
