Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will teach you how to disassemble the control box of the Oculus Rift DK1.
Onderdelen
Geen onderdelen opgegeven.
  1. Use a plastic opening tool to carefully pry off the four rubber feet from the control box. You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet. You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box. You can now remove the bottom lid of the control box. It should come apart easily. You can now remove the bottom lid of the control box. It should come apart easily.
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
Conclusie
Audrey Chan
201 Reputatie
2 handleidingen geschreven
Cal Poly, Team 70-5, Forte Winter 2015 Lid van Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 348
