Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the back panel by firmly sliding it towards the strap.
Push down on the tab under the battery.
Firmly slide the battery away from you. The battery should unlatch from its previous position.
Once the battery is removed, release the tab.
Remove the four 4mm Phillips #000 screws from the back of the remote.
Gently lift the wrist strap to split the back panel into two.
Pull the old buttons off and replace them with the new ones.
