Ga door naar hoofdinhoud
Oculus Rift CV1 Remote Button Replacement
Wat je nodig hebt
  1. Oculus Rift CV1 Remote Button Replacement, Battery: stap 1, afbeelding 1 van 3 Oculus Rift CV1 Remote Button Replacement, Battery: stap 1, afbeelding 2 van 3 Oculus Rift CV1 Remote Button Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the back panel by firmly sliding it towards the strap.
  2. Oculus Rift CV1 Remote Button Replacement: stap 2, afbeelding 1 van 3 Oculus Rift CV1 Remote Button Replacement: stap 2, afbeelding 2 van 3 Oculus Rift CV1 Remote Button Replacement: stap 2, afbeelding 3 van 3
    • Push down on the tab under the battery.
    • Firmly slide the battery away from you. The battery should unlatch from its previous position.
    • Once the battery is removed, release the tab.
  3. Oculus Rift CV1 Remote Button Replacement, Remote Button: stap 3, afbeelding 1 van 1
    • Remove the four 4mm Phillips #000 screws from the back of the remote.
  4. Oculus Rift CV1 Remote Button Replacement: stap 4, afbeelding 1 van 1
    • Gently lift the wrist strap to split the back panel into two.
  5. Oculus Rift CV1 Remote Button Replacement: stap 5, afbeelding 1 van 2 Oculus Rift CV1 Remote Button Replacement: stap 5, afbeelding 2 van 2
    • Gently peel off the top of the control board.
    • Be gentle, if the buttons fall off, try to keep them in the orientation that they were in.
    • If the large black button falls off, place it back into the shell by orienting the tabs on the button to match the holes on the shell.
  6. Oculus Rift CV1 Remote Button Replacement: stap 6, afbeelding 1 van 1
    • Pull the old buttons off and replace them with the new ones.
Conclusie
Christian Perry
223 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G4, White Winter 2019 Lid van Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 770
