Inleiding
If the lenses are cracked or do not show the visuals correctly, you may want to replace the lenses. You will need a Phillips #00 screwdriver and a spudger for this replacement.
Wat je nodig hebt
Pull firmly from the top of the headset facial interface to remove the foam frame.
Move the lenses as close together as possible by sliding the button on the bottom of the frame towards the center of the frame.
Remove the four Phillips #00 4mm screws from the outer edge of the base of the lenses.
3 andere personen hebben deze handleiding voltooid.
