Ga door naar hoofdinhoud
Inleiding
If you find that there is no sound from the headphones and cannot find a solution of how to fix the headphones, perhaps it is time to replace. This guide will show you how to detach the headphones from the head strap. You will need a 4mm Flathead screwdriver for this replacement.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Oculus Rift CV1 Headphones Replacement, Headphones: stap 1, afbeelding 1 van 1
    • Loosen the 4mm Flathead screw from the head strap.
    • Repeat for the headphone on the other side.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jennifer Lai
226 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G4, White Winter 2019 Lid van Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
3 Leden
5 handleidingen geschreven
4 Opmerkingen
can you do a tear down of these headphones?
Julian Chan - Antwoord
Please
John D - Antwoord
A teardown would be very useful please
theSplund - Antwoord
This is an assembly. Could u please fix the issue of the screw getting loose on the actual ear piece, please. Which goes into having to fix something that is a real headache for most of us. please.
Amaya Hiko - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 122
Altijd: 4,188
