Inleiding
If the LEDs in your ORFELD EV-600's brush roller attachment have gone out, this guide will show you how to replace them. The LEDs in the brush roller are a useful tool for seeing while vacuuming dark spaces. Please use caution when using a soldering iron.
Wat je nodig hebt
Place the roller attachment bottom side up so you may access the brush.
Apply pressure with the iFixit opening tool to the tabbed side of the orange cap to release the roller brush.
Remove the 11.5 mm screws surrounding the roller brush divot using a Phillips #0 screwdriver.
Remove the 11.5 mm screws located by the wheels using a Phillips #1 screwdriver.
