Inleiding
Learn how to replace the speakers on the XO-4 Touch.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Flip the top half of the laptop around so you are now looking at the front.
Pull the two speakers out and carefully pull the wire through and out the hole.
Bijna klaar!
Conclusie
