Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the laptop upside-down, with the handle facing away from you.
Pull the lock tabs towards the green outer edges of the laptop.
Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
Lift up on the middle of the battery to remove it from the device.
Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
Flip the laptop over to its normal position.
Lift the two antennas on both sides to unlock the screen.
Open the laptop.
Gently lift up on the back of the keyboard.
Pull the keyboard up far enough to expose the ribbon cable.
Gently lift up on the black connector to release the ribbon cable.
Gently pull the blue plastic tab up and away from the black connector.
Remove the keyboard from the laptop.
Remove the five 4mm Phillips #1 screws from inside the battery compartment
Flip the laptop over, showing the top of the device.
Open the laptop and rotate the screen ninety degrees.
Tilt the screen so the lower right corner of the screen is closer to the lower case.
Push in and lift up on the keyboard edge of the white handle piece.
Pull the piece towards yourself to remove it from the laptop.
Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
Één andere persoon heeft deze handleiding voltooid.
