Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to replace a broken keyboard.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn the laptop upside-down, with the handle facing away from you.
    • Turn the laptop upside-down, with the handle facing away from you.
  2. Pull the lock tabs towards the green outer edges of the laptop. Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. Lift up on the middle of the battery to remove it from the device. Lift up on the middle of the battery to remove it from the device.
    • Lift up on the middle of the battery to remove it from the device.
  4. Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs. Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. Flip the laptop over to its normal position. Lift the two antennas on both sides to unlock the screen. Open the laptop.
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom. Gently lift up on the back of the keyboard.
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. Gently lift up on the black connector to release the ribbon cable. Gently pull the blue plastic tab up and away from the black connector.
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
Conclusie
Michael Kellerman
46 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-30, Amido Winter 2013 Lid van Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Leden
12 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 28
Altijd: 567
