Ga door naar hoofdinhoud
OLPC XO-4 Touch Back Cover Replacement
Wat je nodig hebt
  1. OLPC XO-4 Touch Back Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Back Cover Replacement: stap 2, afbeelding 1 van 2 OLPC XO-4 Touch Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Back Cover Replacement: stap 3, afbeelding 1 van 2 OLPC XO-4 Touch Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Back Cover Replacement, Screen Frame: stap 4, afbeelding 1 van 3 OLPC XO-4 Touch Back Cover Replacement, Screen Frame: stap 4, afbeelding 2 van 3 OLPC XO-4 Touch Back Cover Replacement, Screen Frame: stap 4, afbeelding 3 van 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Back Cover Replacement: stap 5, afbeelding 1 van 3 OLPC XO-4 Touch Back Cover Replacement: stap 5, afbeelding 2 van 3 OLPC XO-4 Touch Back Cover Replacement: stap 5, afbeelding 3 van 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Back Cover Replacement: stap 6, afbeelding 1 van 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Back Cover Replacement: stap 7, afbeelding 1 van 2 OLPC XO-4 Touch Back Cover Replacement: stap 7, afbeelding 2 van 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Back Cover Replacement, Screen: stap 8, afbeelding 1 van 1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Back Cover Replacement: stap 9, afbeelding 1 van 2 OLPC XO-4 Touch Back Cover Replacement: stap 9, afbeelding 2 van 2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Back Cover Replacement: stap 10, afbeelding 1 van 3 OLPC XO-4 Touch Back Cover Replacement: stap 10, afbeelding 2 van 3 OLPC XO-4 Touch Back Cover Replacement: stap 10, afbeelding 3 van 3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Back Cover Replacement: stap 11, afbeelding 1 van 1
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Back Cover Replacement, Back Cover: stap 12, afbeelding 1 van 1
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Back Cover Replacement: stap 13, afbeelding 1 van 2 OLPC XO-4 Touch Back Cover Replacement: stap 13, afbeelding 2 van 2
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
Conclusie
Matthew Smith
23 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-29, Amido Winter 2013 Lid van Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 250
