Ga door naar hoofdinhoud
OLPC XO-1.5 Keyboard and Touchpad Replacement
Wat je nodig hebt
  1. OLPC XO-1.5 Keyboard and Touchpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 3, afbeelding 1 van 3 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 3, afbeelding 2 van 3 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 3, afbeelding 3 van 3
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Keyboard and Touchpad Replacement, Screen Portion: stap 4, afbeelding 1 van 1
    • Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
  5. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Turn the laptop so that the red XO symbol is right side up.
    • Pull off the white plastic panel with your fingers. There will be 4 tabs that hold the white panel in place. It will require moderate force to remove.
    • If you are having difficulty pulling off the white plastic panel, use a spudger.
  6. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the 4 size M2 x .4 x 4mm screws that are connected to the green plastic.
  7. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 7, afbeelding 1 van 1
    • Unplug the white connector with black cables on each end on the left of the hinge.
  8. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Using the Phillips screwdriver, unscrew the 4 size M3 x .5 x 5mm screws holding the metal to the rest of the laptop.
  9. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift the top half that has the screen away from the bottom half.
    • There is still one black cable connecting the two halves. Be sure not to break it.
  10. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 10, afbeelding 1 van 2 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 10, afbeelding 2 van 2
    • Rotate the laptop 180 degrees so that the XO logo is now upside down.
    • Remove the center part of green handle. Push the white plastic back cover down away from the keyboard and top half. This should separate easily from the rest of the device.
  11. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 11, afbeelding 1 van 1
    • Turn the laptop upside down, exposing the bottom inside of the keyboard.
    • This is similar to how the laptop was positioned when removing the battery, except now the white panel is gone.
  12. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 12, afbeelding 1 van 1
    • Slide the black cable (the one that holds the two halves together) out of its connector.
  13. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 13, afbeelding 1 van 2 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 13, afbeelding 2 van 2
    • Separate the screen portion from the rest of the laptop.
  14. OLPC XO-1.5 Keyboard and Touchpad Replacement, Keyboard and Touchpad: stap 14, afbeelding 1 van 2 OLPC XO-1.5 Keyboard and Touchpad Replacement, Keyboard and Touchpad: stap 14, afbeelding 2 van 2
    • Turn the bottom half with the keyboard upside down.
    • Lift the black tab up to free the ribbon cable.
    • Carefully pull the ribbon cable out from the connector.
  15. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 15, afbeelding 1 van 1
    • Lift up the black tab to free the blue ribbon cable.
    • Slide out the blue ribbon cable.
  16. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 16, afbeelding 1 van 1
    • Using a Phillips screwdriver, unscrew the 4 size M2 x .4 x 4mm screws in the corners of the circuit board.
  17. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 17, afbeelding 1 van 1
    • Slide the circuit board away from you.
    • Lift the circuit board out of the laptop to remove it.
  18. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 18, afbeelding 1 van 3 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 18, afbeelding 2 van 3 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 18, afbeelding 3 van 3
    • Using the Phillips screwdriver, unscrew the 6 screws (M2 x .4 x 4mm) connected to the green plastic of the laptop.
    • Remove all of the green plastic parts from the laptop.
  19. OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 19, afbeelding 1 van 3 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 19, afbeelding 2 van 3 OLPC XO-1.5 Keyboard and Touchpad Replacement: stap 19, afbeelding 3 van 3
    • Separate the keyboard from the touchpad. Nothing holds the keyboard and touchpad together, so they should separate easily.
Conclusie
Denzel Moody
43 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-19, Amido Fall 2012 Lid van Cal Poly, Team 3-19, Amido Fall 2012
CPSU-AMIDO-F12S3G19
6 Leden
10 handleidingen geschreven
2 opmerkingen
Step #15 is wrong, disconnect the right blue cable instead of the left.
Michael Bateman - Antwoord
This also works on the XO-1
Lee Greene - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 2,877
