Ga door naar hoofdinhoud
Nvidia Shield Tablet Speaker Replacement
Wat je nodig hebt
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: stap 1, afbeelding 1 van 2 Nvidia Shield Tablet Speaker Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Speaker Replacement: stap 2, afbeelding 1 van 3 Nvidia Shield Tablet Speaker Replacement: stap 2, afbeelding 2 van 3 Nvidia Shield Tablet Speaker Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.16
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Speaker Replacement: stap 3, afbeelding 1 van 2 Nvidia Shield Tablet Speaker Replacement: stap 3, afbeelding 2 van 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: stap 4, afbeelding 1 van 1
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
  5. Nvidia Shield Tablet Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
  6. Nvidia Shield Tablet Speaker Replacement: stap 6, afbeelding 1 van 3 Nvidia Shield Tablet Speaker Replacement: stap 6, afbeelding 2 van 3 Nvidia Shield Tablet Speaker Replacement: stap 6, afbeelding 3 van 3
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
  7. Nvidia Shield Tablet Speaker Replacement: stap 7, afbeelding 1 van 2 Nvidia Shield Tablet Speaker Replacement: stap 7, afbeelding 2 van 2
    $7.16
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Molly Bauer
1.442 Reputatie
6 handleidingen geschreven
USF Tampa, Team 2-2, Blackwell Fall 2015 Lid van USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Leden
11 handleidingen geschreven
1Gids Commentaar
This didn't work
Riley Schork - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 2,703
