Ga door naar hoofdinhoud
Nvidia Shield Tablet Rear Case Replacement
Wat je nodig hebt
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 2 Nvidia Shield Tablet Rear Case Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Rear Case Replacement: stap 2, afbeelding 1 van 3 Nvidia Shield Tablet Rear Case Replacement: stap 2, afbeelding 2 van 3 Nvidia Shield Tablet Rear Case Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.16
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: stap 3, afbeelding 1 van 2 Nvidia Shield Tablet Rear Case Replacement: stap 3, afbeelding 2 van 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Molly Bauer
1.478 Reputatie
6 handleidingen geschreven
USF Tampa, Team 2-2, Blackwell Fall 2015 Lid van USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Leden
11 handleidingen geschreven
1Gids Commentaar
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 3,540
