Ga door naar hoofdinhoud
Nvidia Shield Tablet Motherboard Replacement
Wat je nodig hebt
  1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 2 Nvidia Shield Tablet Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Motherboard Replacement: stap 2, afbeelding 1 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 2, afbeelding 2 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Motherboard Replacement: stap 3, afbeelding 1 van 2 Nvidia Shield Tablet Motherboard Replacement: stap 3, afbeelding 2 van 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    $7.95
    • Carefully use the precision tweezers to unplug the ribbon cable.
    • Be sure to have your anti-static wrist strap on for this procedure.
  5. Nvidia Shield Tablet Motherboard Replacement: stap 5, afbeelding 1 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 5, afbeelding 2 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
  6. Nvidia Shield Tablet Motherboard Replacement: stap 6, afbeelding 1 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 6, afbeelding 2 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
    • Use the flat end of the spudger tool to carefully pry up the motherboard.
    • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
  7. Nvidia Shield Tablet Motherboard Replacement: stap 7, afbeelding 1 van 2 Nvidia Shield Tablet Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Desolder the positive and negative battery cables from the motherboard.
    • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
    • The motherboard should now come free.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Molly Bauer
1.478 Reputatie
6 handleidingen geschreven
USF Tampa, Team 2-2, Blackwell Fall 2015 Lid van USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Leden
11 handleidingen geschreven
9Gids Commentaar
Where do you obtain a new motherboard?
imprintcave - Antwoord Deel
The real question is more about how to find a new shield tablet motherboard ??
willixlive - Antwoord Deel
where can i buy the motherboard
Gurjot Dhaliwal - Antwoord Deel
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - Antwoord Deel
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 56
Altijd: 10,008
