Ga door naar hoofdinhoud
Nvidia Shield Tablet K1 Back Panel Replacement
Wat je nodig hebt
  1. Nvidia Shield Tablet K1 Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Back Panel Replacement: stap 2, afbeelding 1 van 2 Nvidia Shield Tablet K1 Back Panel Replacement: stap 2, afbeelding 2 van 2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Ryan Butler
1.882 Reputatie
9 handleidingen geschreven
2Gids Commentaar
Hello, I’m planning on replacing the battery on my K1 soon, will the rear panel snap back in?
Scott - Antwoord
but wait theres flex cable your not showing thats attached to the cover it could be ripped off and bricked like mine because no one know the name of said cable
Christian Rogers - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 31
Altijd: 5,415
