Ga door naar hoofdinhoud
Nvidia Shield TV 1st Generation Controller Battery Replacement
Wat je nodig hebt
  1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: stap 1, afbeelding 1 van 2 Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: stap 1, afbeelding 2 van 2
    • Remove the indicated six screws using the T6 Torx screwdriver.
  2. Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 2, afbeelding 1 van 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to pry the face of the controller away from the body.
    • Make sure the controller is face down during this step as the buttons can easily fall out.
  3. Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the indicated ribbon wires from the face of the controller.
  4. Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 4, afbeelding 1 van 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    $3.99
    • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
    • Lift the vibration motor out of the front case.
    • Repeat for the other side.
    • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
  5. Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 5, afbeelding 1 van 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 5, afbeelding 2 van 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 5, afbeelding 3 van 3
    • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
    • Lift the logic board away from the front case.
  6. Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 6, afbeelding 1 van 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 6, afbeelding 2 van 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: stap 6, afbeelding 3 van 3
    • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
    • Remove the panel from the front case.
    • Lift the battery from the front case to remove it.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Joshua Neally
581 Reputatie
4 handleidingen geschreven
USF Tampa, Team S16-G6, Eyestone Fall 2017 Lid van USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Leden
8 handleidingen geschreven
8Gids Commentaar
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - Antwoord
LC18650 Remote Control accu
djcornelissen - Antwoord
Are battery packs available for the 2017 controller?
Andrew - Antwoord
Simply reconnecting the battery fixed my issues
Charles Keisler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 151
Altijd: 20,709
