Inleiding
You will need to replace the battery in your controller if it is not holding a charge or your controller is not turning on. When taking apart the controller, be careful as the buttons are not held in place by anything and can easily fall out.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$3.99
Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
Lift the vibration motor out of the front case.
Repeat for the other side.
Use the angled tweezers to remove the battery cable, moving it upward from its socket.
12 andere personen hebben deze handleiding voltooid.
8Gids Commentaar
Where can i buy the replacement Battery? What tags should i use to find it?
LC18650 Remote Control accu
Simply reconnecting the battery fixed my issues
