Inleiding
If your charging port, USB ports, ethernet port, or HDMI port on your Nvidia Shield Pro Android TV are not working properly, use this guide to help remove/replace your I/O board on your Nvidia Shield Pro. The only tools required for this procedure are the T6 Torx screwdriver and the plastic opening tool. Some steps may be difficult due to the cluster of screws and wires to be located, but do not fret, this guide will help you locate all the parts you need to remove.
Wat je nodig hebt
Flip to the back side of your Nvidia Shield Pro Android TV.
To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
Detach the brown side of the connector from the I/O board by pulling it upward.
Remove the screw from the silver plate using a T6 Torx screwdriver.
Put the cable aside after removing it.
8 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
