Ga door naar hoofdinhoud
Nvidia Shield Pro Android TV Controller Thumbsticks Replacement
Wat je nodig hebt
  1. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: stap 1, afbeelding 1 van 3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: stap 1, afbeelding 2 van 3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: stap 1, afbeelding 3 van 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: stap 2, afbeelding 1 van 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: stap 3, afbeelding 1 van 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: stap 3, afbeelding 2 van 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: stap 4, afbeelding 1 van 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: stap 4, afbeelding 2 van 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: stap 5, afbeelding 1 van 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: stap 5, afbeelding 2 van 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ben Carrasco
347 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G2, White Winter 2020 Lid van Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Leden
14 handleidingen geschreven
3Gids Commentaar
Very good instructions that were very helpful. Do you have recommendations on which thumbsticks are the best since the shield seems to have wider and deeper ones? Thanks again for the guide.
Charles Brodie - Antwoord
Just wondering where would I be able to buy a thumbstick spare part to replace it.
xguyun - Antwoord
Thanks, very good post, and it could be very useful for me. Just wondering where would I be able to buy a spare part for this thumbstick to replace my broken one.
xguyun - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 56
Altijd: 2,367
