Ga door naar hoofdinhoud
Nvidia Shield Pro Android TV Controller Rumble Motor Replacement
Wat je nodig hebt
  1. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: stap 1, afbeelding 1 van 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: stap 1, afbeelding 2 van 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: stap 1, afbeelding 3 van 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: stap 2, afbeelding 1 van 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: stap 3, afbeelding 1 van 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: stap 3, afbeelding 2 van 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: stap 4, afbeelding 1 van 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: stap 4, afbeelding 2 van 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: stap 5, afbeelding 1 van 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: stap 6, afbeelding 1 van 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: stap 6, afbeelding 2 van 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: stap 6, afbeelding 3 van 3
    • Grip the plugs as close to their ports as possible and pull them directly up and out.
    • Lift the rumble motors up and out of the chassis.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 272
